Is there any way to get the HTTP POST hidden fields using irules and then send the information to the backend servers?
Thanks,
kapil
Thanks,
kapil
We have been talking about adding a feature to make POST field extraction a little bit easier but for now you will have to do an HTTP::collect and use the HTTP::payload command to access and parse the data.
Thanks for your reply. Let me explain our existing rules and what I am trying to achieve:
Existing rules:
if { [active_members servpool1] == 1 } {
log “pool1 is up”
set uri [HTTP::uri]
log “the initial http uri is: $uri”
if { $uri starts_with “/logon\.mic” } {
set new_uri [string replace $uri 0 10 /mic/SignIn.mic]
HTTP::uri “$new_uri”
pool servpool1
log “The replaced URL is: $new_uri”
elseif { $uri starts_with “/ea/” } {
set new_uri [string range $uri 3 end]
log “the new URI is: $new_uri”
pool servpool1
log “the new HTTPURI is $new_uri”
This is what we want to achieve:
1: We want to retrive a post field named “data” from the initial request from the client
2: then set the new_uri variable to :
set new_uri [string replace $uri 0 10 /mic/SignIn.mic?data=$data]
where $data is the post field retrieved from the client request.
How can we do that?
Thanks,
Kapil
You would need to run HTTP::collect when you detect that you are dealing with the form. Then in the HTTP_REQUEST_DATA event, you need to search for the field and can then rewrite the uri to include the data. Try searching for collect and HTTP_REQUEST_DATA to see some examples of collecting HTTP payload.
