HTTP::path -normalized (TMOS 13) issue?
According to the Wiki,
should do:
the normalization involves lower-casing, removing unnecessary directory traversals, convert from microsoft style %uxxxx form to the standard %xx hex form, bytes not allowed in a uri are normalised to their percent-encoded representation, bytes percent-encoded when they don’t need to be are changed to their normal representation
My experience (TMOS 13.1) is that:
  • conversion to lower case does not work at all!
  • "%2E%2E"
    is converted to
    (OK)
  • "/foo/../bar"
    is converted to
    "/bar"
    (OK)
However (FAIL):
  • "/foo/%2E%2E/bar"
    is (only) converted to
    "/foo/../bar"
It seems that directory traversal normalization is (incorrectly) performed before %-normalization. I would expect to first do %-normalization and then normalize directory traversal…
So, in order to perform normalization correctly, I need to do this (I need to retain the original URI in the request to the pool member):
set origPath [HTTP::path]
  set normPath [string tolower [HTTP::path -normalized]]
  HTTP::path $normPath
  set normPath [HTTP::path -normalized]
  HTTP::path $origPath
  log local0. "Path  : \"$origPath\" --> \"$normPath\""
I would have expected to do this, though:
  log local0. "Path  : \"[HTTP::path]\" --> \"$normPath\""
Is there a more elegant way to perform normalization on the URI/PATH?
And can this be fixed, please?
Apparently the system goes through one pass only, and 2 passes seem to be good enough for your situation.
It would be better for the system to use a loop, and break out if the output is equal to the input.
You might want to open a support case so that F5 developers are aware of this issue.
As an addendum to the response from Jie
The canonical word on the operations of normalize are
1) The case of scheme is normalized to lower-case.
2) The hostname is normalized to lower-case. A possible trailing ‘.’ is removed from the hostname.
3) IP addresses are normalized. There are many ways to write an IP address (v4 and v6). These are cannonicalized to a normal form.
4) Ports are normalized. Unnecessary port annotations (like :80 on a http request) are removed.
5) Paths are normalized, with extra unneeded directory traversals removed.
6) Percent-encoding normalization. Bytes not allowed in a uri are normalized to their percent-encoded representation. Bytes percent-encoded when they don’t need to be are changed to their normal representation. We convert from microsoft style %uxxxx form to the standard %xx hex form.
7) Fragment specifiers are removed.
So - HTTP::uri/HTTP::path -normalize should not change the case of a URI.
The documentation for HTTP::uri is probably clearer.
I got confirmation by F5 support that lower-casing is not intended (and not performed) and the Wiki documentation (HTTP::path -normalize) is in error.
I also got a bug-id concerning the order of “directory traversal normalization” and “%-normalization.”:
bug ID708068 (HTTP: normalize directory traversal after percent-encoding)
I have requested to add this to the known issues section of the Wiki (HTTP::path).
Thanks for reporting back.
