I have 3 servers which is running HTTP server. I am able to connect to web servers from load balancer’s command line interface to those web servers. However when I give HTTP as heath check monitor it is failing. When I gave tcp/ICMP as health monitor, it is working. Also, I created a vip and connected to the same pool, the vip is not delivering website. I tried to connect the website from the same network using other computers browser. It is working fine. Please help me to solve the issue..
ciscofriend,
A couple of things, the default HTTP monitor users HTTP version 0.9, rather than 1.0 or 1.1. You could try and change the monitor to use either of the later versions of http, see Constructing HTTP requests for use with the HTTP or HTTPS application health monitor
Also, what happens if you do tcpdump, does this give any clues?
tcpdump -nni 0.0 -s0 host x.x.x.x and port 80
Hope this helps,
N
