HTTP monitoring in GTM
It turns out that in GTM, an HTTP monitor will immediately down a server upon a failure. There is no “you can fail 3 times in a row before I mark you down” in GTM. Thus, I have tried to write a shell script as an EAV for GTM that does the same thing:
!/bin/sh
  (c) Copyright 1996-2007 F5 Networks, Inc.
  This software is confidential and may contain trade secrets that are the
  property of F5 Networks, Inc.  No part of the software may be disclosed
  to other parties without the express written consent of F5 Networks, Inc.
  It is against the law to copy the software.  No part of the software may
  be reproduced, transmitted, or distributed in any form or by any means,
  electronic or mechanical, including photocopying, recording, or information
  storage and retrieval systems, for any purpose without the express written
  permission of F5 Networks, Inc.  Our services are only available for legal
  users of the program, for instance in the event that we extend our services
  by offering the updating of files via the Internet.
  @() $Id: http_monitor_cURL+GET,v 1.0 2007/06/28 16:10:15 deb Exp $
  (based on sample_monitor,v 1.3 2005/02/04 18:47:17 saxon)
  these arguments supplied automatically for all external monitors:
  $1 = IP (IPv6 notation. IPv4 addresses are passed in the form
                          ::ffff:w.x.y.z
                          where "w.x.y.z" is the IPv4 address)
  $2 = port (decimal, host byte order)
  Additional command line arguments ($3 and higher) may be specified in the monitor template
  This example does not expect any additional command line arguments
  Name/Value pairs may also be specified in the monitor template
  This example expects the following Name/Vaule pairs:
   URI  = the URI to request from the server
   RECV = the expected response (not case sensitive)
   TRY = the number of tries
  remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
 IP=`echo ${1} | sed 's/::ffff://'`
 PORT=${2}
 PIDFILE="/var/run/`basename ${0}`.${IP}_${PORT}.pid"
  kill of the last instance of this monitor if hung and log current pid
 if [ -f $PIDFILE ]
 then
    kill -9 `cat $PIDFILE` > /dev/null 2>&1
 fi
 echo "$$" > $PIDFILE
 success=0
 n=${TRY}
  loop TRY times
 for (( i = 1; i <= $n; i++ ))
 do
  send request & check for expected response
    curl -fNsi http://${IP}:${PORT}${URI} | grep -i "${RECV}" 2>&1 > /dev/null
  mark node UP if expected response was received
    if [ $? -eq 0 ]
    then
        success=1
    fi
    sleep 3
 done
 if [ $success == 1 ]
 then
     echo "UP"
 fi
 rm -f $PIDFILE
 exit
It seems to work, but I don’t quite feel sure about it. Can someone look this over for errors? Thanks.
