HTTP Monitor
Hi, I am trying to configure an HTTP monitor with following send and receive string but this monitor mark my pool as down
Send string = GET /xyz.abc.dyx.ezt.co.uk/alive HTTP/1.1\r\n Receive= alive
Server return correct status code e.g if page directly access from server it returns following in header URL : ezt.co.uk — Domain Name For Sale | DomainStore Request Method: GET Status Code: 200 OK Remote address : X.X.X.X:80 ( IP address of VIP )
Respone : alive
I am not sure if my send string is correct ? I m using 11.6.0
Regards
If you use HTTP/1.1 in your GET method, the receiving server also expects a Host header. So try something like:
GET /xyz.abc.dyx.ezt.co.uk/alive HTTP/1.1\r\nHost: host.domain.com\r\nConnection: Close\r\n
Or:
GET /xyz.abc.dyx.ezt.co.uk/alive HTTP/1.0\r\n
Try this:
GET /alive HTTP/1.1\r\nHost: xyz.abc.dyx.ezt.co.uk\r\nConnection: Close\r\n\r\n
If it doesn’t work, you can use this CURL command to check the output from bash on the F5:
curl -H "Host: xyz.abc.dyx.ezt.co.uk" http://x.x.x.x/alive
You can also use the following from bash for troubleshooting http monitor:
echo -e "GET /alive HTTP/1.1\r\nHost: xyz.abc.dyx.ezt.co.uk\r\nConnection: Close\r\n\r\n" | nc x.x.x.x 80
x.x.x.x is the IP of the pool member
Since you are running 11.6, you may be able to troubleshoot better using /var/log/monitors:
Look under “monitor logging” - 404 Page not found | BIG-IP Documentation
