Zdenda
February 17, 2012, 8:13pm
1
Hi there,
I have to use HTTP monitor which will contain URL and URI and is expecting OK reply.
I am using BIGIP 10.2.3 and my HTTP monitor send string is now like this:
GET /web/default.aspx HTTP/1.1\r\nHost: tested.domain.com \r\nConnection: Close\r\n\r\n
But currently this is not working and I cannot find whats wrong, does anybody know whats wrong?
Thanks,
Zdenek
Hamish
February 17, 2012, 8:38pm
2
Can you
1. Post the config for the monitor
2. Do a tcpdump and view the stream (To a dump file via -w and use wireshark to get the data)
3. Have a look at the web serve access and error logs for any status returns and errors
H
Hamish
3
Can you
2. Do a tcpdump an viewvthe stream
3. Hav a look at e web serve access log for any errors
H
Zdenda
February 19, 2012, 6:55pm
4
Hi, thanks, here it is
1)
monitor my_http_monitor {
defaults from http
partition Intranet
recv “OK”
send “GET /atest/web/default.aspx HTTP/1.1\r\n Host: myprivatesite.biz\r\n Connection: close\r\n\r\n\”
2) I have gone through tcpdump:
Requests are like this:
Expert Info (Chat/Sequence): GET /atest/web/default.aspx HTTP/1.1\r\n
Response:
Expert Info (Chat/Sequence): HTTP/1.1 400 Bad Request\r\n
I think those are most important from dump?
3) I will ask resp. people for that server.
Thanks,
Zdenek
nitass
February 20, 2012, 6:23am
5
send "GET /atest/web/default.aspx HTTP/1.1\r\n Host: myprivatesite.biz\r\n Connection: close\r\n\r\n\"is the last back slash (\) excess?
Zdenda
February 20, 2012, 8:39am
6
Hi, yes it’s typo. That slash is out and situation still the same.
I get 400 The request is badly formed.
I have compared TCPdump when it works from IE and TCPdump when monitor from F5 and those are same, but wireshark doesnt show me everything..
nitass
February 20, 2012, 9:09am
7
have you tried to telnet to pool member and send a request?
Connection: close
Zdenda
February 20, 2012, 9:21am
8
I tried to telnet to member and paste my command with \r\n. It didnt work.
Now I tried your template and I got 401 unauthorized, so there is some progress:-)
But why it didnt work with \r\n ?
Z
nitass
February 20, 2012, 9:25am
9
But why it didnt work with \r\n ?since you have to press enter key, you do not need to put \r\n.
Now I tried your template and I got 401 unauthorized, so there is some progress:-)does web server require authentication? if so, what is authentication method?
this sol also includes send string with basic authentication.
sol2167: Constructing HTTP requests for use with the HTTP or HTTPS application health monitor
hope this helps.
Zdenda
February 20, 2012, 9:51am
10
Hmm, I have to find out why IIS doesnt accept requests with \r\n and then I will try to solve that authentication issue. I am quite lost at the moment, I tried many shapes of requests but still get the same: Error 400. The request is badly formed
nitass
February 20, 2012, 10:10am
11
what i think is your web server requires authentication and OK will be received if authentication successes.
by the way, Aaron has written very good health monitor troubleshooting guide as follows.
Troubleshooting Ltm Monitors by Aaron
http://devcentral.f5.com/wiki/AdvDesignConfig.TroubleshootingLtmMonitors.ashx
hope this helps.
