Can i setup http monitor which send string as “GET /samplewebpage/something.jsp”.Receive string condition should be ‘if the response from this GET request doesn’t cross 1 sec’. Means if the page loading takes more than 1 sec to load, then the pool member will be marked as down.This means BIGIP should intercept the “timing” section (when you hit F12 on browser, Network → Timings-> response value) So is this can be achieved ? if yes how to configure the receive string. Please suggest.
Hello,
You can try to change your interval and timeout settings in your monitor to 1sec.
Regards
