HTTP Monitor with multiple requests
I have been challenged to create a monitor to manage an application. I need to create a monitor that will log into an application and then make a further request.
So…
I have the POST request together to login and the request that the authenticated user has to then make, I just can’t figure out how to order/relate these in the simplest way.
I’m probably missing the obvious here but has anybody got any thoughts?
Regards,
N
Hi Notorious BIGIP
Have you looked at the following Codeshare for Monitors
Thanks, CB
Bhattman,
I actually didn’t know about the Monitor Codeshare :wink: I think the Super HTTP Monitor DevCentral - An F5 Technical Community is answer I was looking for.
Thanks for the point in the right direction :wink:
N
NP. Please come back if you are having trouble with the code. There are many here would can assist
Bhattman,
There was one issue with the monitor and it was to do with the SCRIPTNAME variable, the script pulls this in from the calling monitor e.g. /Common/myMonitor A problem then occurs as the script attempts to use this variable as part of the tmpfile name e.g. /var/run//Common/myMonitor/… and the script fails. In short I don’t think this script has been updated to accommodate the new object naming that cam in in late v10.
I have one more question you might be able to answer. I understand that superHTTP is about chaining multiple requests together but do you know if the script would follow a redirect or whether I would have to hard code this? I am presuming I have to hard code at this stage.
Thanks,
Notorious
Just tested to see if the script naturally follows redirects and it doesn’t so you just need to hard code a request for the redirected location :wink:
