HTTP monitor issue
I have a VE machine, BigIP BIG-IP 11.2.1 Build 807.0 Hotfix HF1
When trying to create a custom HTTP Monitor with custom headers (as seen in 404 Page not found | BIG-IP Documentation)
the monitor then returns Error 400 Bad Request, when tracing we see that the headers arrive twice in the same request.
Can you post your monitor configuration please (minus sensitive data)?
I can post TCP Stream
GET /api/charm/monitor HTTP/1.1 Host: myhost.com User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:23.0) Gecko/20100101 Firefox/23.0 Accept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8 Accept-Language: en-US,en;q=0.5 Accept-Encoding: gzip, deflate Connection: keep-alive
HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 13 Oct 2013 13:37:49 GMT Connection: close Content-Length: 339
host.com"> Bad Request
Bad Request - Invalid Header
HTTP Error 400. The request has an invalid header name.
this is mine.
[root@VIP4400-R69-S33:/S2-green-P:Active:Standalone] config  tmsh list ltm monitor http myhttp
ltm monitor http myhttp {
    defaults-from http
    destination *:*
    interval 5
    send "GET /api/charm/monitor HTTP/1.1\\r\\nHost: myhost.com\\r\\nUser-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:23.0) Gecko/20100101 Firefox/23.0\\r\\nAccept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8\\r\\nAccept-Language: en-US,en;q=0.5\\r\\nAccept-Encoding: gzip, deflate\\r\\nConnection: keep-alive\\r\\n\\r\\n"
    time-until-up 0
    timeout 16
[root@VIP4400-R69-S33:/S2-green-P:Active:Standalone] config  ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 200.200.200.33(41254) <-> 200.200.200.101(80)
1381792390.8140 (0.0013)  C>S
Host: myhost.com
1381792390.8156 (0.0015)  S>C
HTTP/1.1 404 Not Found
Date: Tue, 15 Oct 2013 13:03:00 GMT
Server: Apache/2.2.3 (CentOS)
Content-Length: 290
Connection: close
Content-Type: text/html; charset=iso-8859-1
404 Not Found
Not Found
The requested URL /api/charm/monitor was not found on this server.
Apache/2.2.3 (CentOS) Server at myhost.com Port 80
It may be worthwhile to troubleshoot this from cURL on the command line. Use the -v option for extra verbosity, and use the -H option to add additional headers. Example:
curl -v http://10.10.10.10/api/charm/monitor -H "Host: myhost.com" -H "User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:23.0) Gecko/20100101 Firefox/23.0" -H "Accept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8" -H "Accept-Language: en-US,en;q=0.5" -H "Accept-Encoding: gzip, deflate" -H "Connection: keep-alive"
