HTTP Health monitor
Hi I am trying to setup a health monitor for one of our applications but it is taking the servers down when applied. The syntax I am using is as follows even though the receive string is found on the page.
Send string: GET /TE_x_UAT/Webui/AccessDenied.html HTTP/1.1\r\nHost:x.x.x\r\nConnection: Close\r\n\r\n Receive String: Your user account does not have access to this page
It seems receive string is longer then expected. Is it possible to short String instate of
Run below command to check receive string. Take TCPDUMP also
curl -gv http://:/TE_x_UAT/Webui/AccessDenied.html
when I try to run a curl on that I get * getaddrinfo(3) failed for ::80 * Couldn’t resolve host ‘:’ * Closing connection 0 curl: (6) Couldn’t resolve host ‘:’
the host is stated later on in the string
Thanks I managed to get the curl command to work and have picked a new receive string and the monitors are now showing the pool members as up.
Many thanks
