I am trying to insert the HTTP header X-XSS-Protection, X-Content-Type-Options in order to mitigate a security vunerability. I have found an irule solution, but when I implemented the solution, a code error appears.Can anyone share the correct syntax for this please? when HTTP_RESPONSE {
if { !([ HTTP::header exists "X-Content-Type-Options“ ])} { HTTP::header insert “X-Content-Type-Options” “‘nosniff’” }
if { !([ HTTP::header exists "X-XSS-Protection“ ])} { HTTP::header insert “X-XSS-Protection” “1; mode=block” } }
01070151:3: Rule [/OHSBC/Ohsbc] error: /OHSBC/Ohsbc:17: error: [parse error: PARSE missingQuote 515 {missing "}][{ !([ HTTP::header exists "X-Content-Type-Options“ ])}] /OHSBC/Ohsbc:18: error: [parse error: PARSE missingQuote 645 {missing "}][{ !([ HTTP::header exists "X-XSS-Protection“ ])}]
You had an incorrect quotation mark at the end of your header type in the IF statement. This was preventing the close braces from working correctly.
I’ve corrected the code:
if {!([HTTP::header exists "X-Content-Type-Options" ])} {
HTTP::header insert "X-Content-Type-Options" "'nosniff'"
if {!([ HTTP::header exists "X-XSS-Protection"])} {
HTTP::header insert "X-XSS-Protection" "1; mode=block"
Hey
I’ve only corrected you syntax
if { ! [HTTP::header exists "X-Content-Type-Options"] } {
if { ! [HTTP::header exists "X-XSS-Protection"] } {
Now you should be able to create it.
Please give me a feedback
Regards
How can we verify that the iRule for XSS protection works? is there a command to verify the iRule works or a way to test it ?
