We have multiple HA pairs of F5 VMs in production running BigIP 12.1.3 and we have some quirky issues with iRules most commonly when using HTTP::header and I’d like some help if anyone has insight on the issue.
This works on one production pair:
STREAM::disable
HTTP::header remove “Accept-Encoding”
when HTTP_RESPONSE {
STREAM::disable
if { [HTTP::header is_redirect] } {
HTTP::header replace Location [string map -nocase {http://my.example2-test.com/ https://my.example2-test.com/} [HTTP::header value Location]]
HTTP::header replace Location [string map -nocase {http://my.example2.com/ https://my.example2.com/} [HTTP::header value Location]]
if {[HTTP::header value Content-Type] contains “text”} {
STREAM::expression {@http://my.example2.com/@https://my.example2.com/@ @http://my.example2.com/@https://my.example2.com/@}
STREAM::enable
But this, which is identical aside from the hostname, does not work on another production pair:
STREAM::disable
STREAM::disable
HTTP::header replace Location [string map -nocase {http://my.example.com/ https://my.example.com/} [HTTP::header value Location]]
STREAM::expression {@http://my.example.com/@https://my.example.com/@}
STREAM::enable
Both have HTTP and stream profiles attached to the virtual server, but the failing one produces the following TCL error in the logs:
F5 tmm3[10375] 01220001 TCL error: /Common/rewrite-my.example.com-https <HTTP_REQUEST> - Operation not supported (line 1) invoked from within “HTTP::header remove “Accept-Encoding””
I have another iRule using HTTP::header that also throws TCL errors that makes no sense, as I’ve tried pretty much every variation on parameters (variables, with quotes, without quotes):
set client_port [TCP::client_port]
if {!([HTTP::header exists “X-Forwarded-Port”])} {
HTTP::header insert “X-Forwarded-Port” $client_port
But it throws this error consistently:
TCL error: /Common/x-forwarded-port <HTTP_REQUEST> - Operation not supported (line 3) invoked from within “HTTP::header insert “X-Forwarded-Port” $client_port”
Can anyone shed light on why this happens? To make matters more confusing, the working iRule is on pair A, the duplicate broken iRule is on pair B, and the broken insert iRule is on pair A.
