HTTP header insert with CN and for SHA1 thumbprint of the SSL certificate ?
Hi Any one help to edit the below irule to match my requirement, HTTP header insert with CN(Certificate name) and for SHA1 thumbprint of the SSL certificate to backend servers.
LTM VIP is HTTPS with only client SSL profile
Members are connected to LB with port 3000, No Server Side SSL profile.
when CLIENTSSL_HANDSHAKE
set cur [SSL::sessionid]
set ask [session lookup ssl $cur]
if { $ask eq “” } {
session add ssl [SSL::sessionid] [SSL::cert 0]
when HTTP_REQUEST
set id [SSL::sessionid]
set the_cert [session lookup ssl $id]
if { $the_cert != “”}
HTTP::header insert X-Client-Cert [X509::whole $the_cert]
Take it you want the client certificate data inserted as HTTP headers?
The following does this generally, you will need to pick the parts you want from the iRule X509 options:
when CLIENTSSL_CLIENTCERT priority 100 {
    if {[SSL::cert count] > 0} {
        set clientCert [X509::whole [SSL::cert 0]]
        set clientCertSubject [X509::subject [SSL::cert 0]]
        foreach field [ split $clientCertSubject ","] {
            if {$field starts_with "CN="} {
                set clientCommonName [getfield $field "=" 2]
    if {(info exists clientCert) && ($clientCert ne "") } {
        HTTP::header insert X-Client-Cert $clientCert
    if {(info exists clientCommonName) && ($clientCommonName ne "") } {
        HTTP::header insert X-Client-CN $clientCommonName
Thanks, I modified it please check once
set cert_hash [X509::hash [SSL::cert 0]]
foreach field [ split $clientCertSubject “,”] {
if {$field starts_with “CN=”} {
set clientCommonName [getfield $field “=” 2]
if {(info exists clientCert) && ($clientCert ne “”) } {
if {(info exists clientCommonName) && ($clientCommonName ne “”) } {
        set clientCertHash [X509::hash [SSL::cert 0]]
    if {(info exists clientCert) && ($clientCert ne "")} {
    if {(info exists clientCommonName) && ($clientCommonName ne "")} {
    if {(info exists clientCertHash) && ($clientCertHash ne "")} {
        HTTP::header insert X-Client-hash $clientCertHash
Thanks for your time, I will test it and let you know result
I am bothering you,
I am getting in big error, when adding the rule to f5
01070151:3: Rule [/Common/rulename] error: /Common/rulename:15: error: [parse error: PARSE syntax 466 {syntax error in expression “(info exists clientCert) && ($clientCert ne “”)”: looking for close parenthesis}][{(info exists clientCert) && ($clientCert ne “”)}]
/Common/rulename:19: error: [parse error: PARSE syntax 587 {syntax error in expression “(info exists clientCommonName) && ($clientCommonName ne “”)”: looking for close parenthesis}][{(info exists clientCommonName) && ($clientCommonName ne “”)}]
/Common/Qvantel-BSSAP-SIT:23: error: [parse error: PARSE syntax 724 {syntax error in expression “(info exists clientCertHash) && ($clientCertHash ne “”)”: looking for close parenthesis}][{(info exists clientCertHash) && ($clientCertHash ne “”)}]
Sorry didn’t have time to test and missed some [ ] out
    if {([info exists clientCert]) && ($clientCert ne "")} {
    if {([info exists clientCommonName]) && ($clientCommonName ne "")} {
    if {([info exists clientCertHash]) && ($clientCertHash ne "")} {
I got my application team saying, they expecting this Header names,
  • X-SSL-Client-CN
    • X-SSL-Client-SHA1
Should i change as below?
please verify once
if {([info exists clientCert]) && ($clientCert ne “”)} {
if {([info exists clientCommonName]) && ($clientCommonName ne “”)} {
HTTP::header insert X-SSL-Client-CN $clientCommonName
if {([info exists clientCertHash]) && ($clientCertHash ne “”)} {
HTTP::header insert X-SSL-Client-SHA1 $clientCertHash
