HTTP::header insert somename somevalue
inserts “HTTP_” before the specified variable name of “somename”. Is it possible to have it not inserted - to have the HTTP header with exactly the specified header name “somename”?
HTTP::header should insert it exactly as given. It does not prepend “HTTP_” on my system:
when HTTP_RESPONSE {
HTTP::header insert headername headervalue
gives
HTTP/1.1 200 OK
Date: Tue, 02 Jun 2009 22:26:02 GMT
Accept-Ranges: bytes
Content-Length: 45
Connection: close
Content-Type: text/html
headername: headervalue
and doing it for requests works similarly. Perhaps you should try logging the contents of the parameters you pass to HTTP::header.
The webserver may provide CGI variables with HTTP_ prepended to indicate the values were generated from HTTP headers in the client’s request:
http://hoohoo.ncsa.illinois.edu/cgi/env.html
In addition to these, the header lines received from the client, if any, are placed into the environment with the prefix HTTP_ followed by the header name. Any - characters in the header name are changed to _ characters. The server may exclude any headers which it has already processed, such as Authorization, Content-type, and Content-length. If necessary, the server may choose to exclude any or all of these headers if including them would exceed any system environment limits.
Aaron
