Hello Friends
I’m having these errors about “HTTP Header Exceeded maximmum allowed size”:
Feb 6 15:49:59 BOGEAWF5LTMP01 err tmm[11181]: 011f0005:3: HTTP header (36400) exceeded maximum allowed size of 36000 (Client side: vip=/Common/VS_PX_IGUANA profile=http pool=/Common/Proxy_Pool client_ip=10.162.153.36) Feb 6 15:50:02 BOGEAWF5LTMP01 err tmm[11181]: 011f0005:3: HTTP header (36400) exceeded maximum allowed size of 36000 (Client side: vip=/Common/VS_PX_IGUANA profile=http pool=/Common/Proxy_Pool client_ip=10.162.153.36) Feb 6 15:50:06 BOGEAWF5LTMP01 err tmm1[11181]: 011f0005:3: HTTP header (36400) exceeded maximum allowed size of 36000 (Client side: vip=/Common/VS_PX_IGUANA profile=http pool=/Common/Proxy_Pool client_ip=10.162.153.36)
I did search info about that error, and i found an Irule in this Link: DevCentral - An F5 Technical Community
The Irule is following:
Check the total HTTP headers size
if {[string length [HTTP::request]] > 10000 }{
Check if the URI is very long
if {[string length [HTTP::uri]] > 1000}{
log local0. "Uri is long. Length [string length [HTTP::uri]], URI: [HTTP::uri]"
Exit this event from this iRule
return
Loop through the headers by name
foreach header {[HTTP::header names]} {
Check for a long header value
if {[string length [HTTP::header value $header]] > 1000 } {
log local0. "Header is long. Header Name: $header,\
Length: [string length [HTTP::header value $header]], Value: [HTTP::header value $header]"
return
If we are still here the request was large, but not the URI or any single header.
Log the first 1k bytes of the full request
log local0. "Request is long: [HTTP::request]"
I used this irule to log the header values, but this irule affects the HTTPS connections that not terminating in the F5. I am balancing two Bluecoat Proxies but the SSL interception is being done in the Proxies directly. You can help me with a modification from this irule to avoid this behavior?
