http forwarding with irule
hello,
I will confiugure a irule to forward to specific URL
the connection will be open to my VIP https://server1.com/123/456.html
and the BIGIP should forward this to http://testserver.de/123/456.html
my suggestion
if { [HTTP::host] matches_regex “server1.com” } {
and now forward to http://testserver.de[HTTP::uri]
please help
Hi there
Do you wish to forward the traffic to the second server or redirect the client to that second server?
If you are forwarding the traffic - then the second server could just be in a bigip pool that is referenced either by the irule or as a default pool for the VS.
If you are redirecting have a look at the HTTP::redirect function as this should be able to work.
I hope this helps
hello
Ok, a redirect is not possible because the client should open the connection to testserver1.de about the VIP on the LB https://server1.com
This is like a tunneling
the client shouldn’t notice does he connecting another host
sorry to adjustment
the client shouldn’t notice does he get data from another host
Do you need to forward using the DNS name (testserver.de)?
If you can use the IP address instead, you could simply do the following since you are not changing the URI:
        if { [HTTP::host] matches_regex "server1.com" } {
            Replace the Host: header with the new name
           HTTP::header replace "host" "testserver.de"
            You could also modify the uri with HTTP::uri "new uri"
            a.b.c.d is the IP address of testserver.de
           use node a.b.c.d 80
If you do need to use the DNS name, then you will want to look at the following post:
Click here for link
Thanks for your help!
It works fine, the final irule:
    set uri [HTTP::uri]
    set new_host testserver.de
    set new_url $new_host$uri
       HTTP::uri http://$new_url
Cheers
