HTTP error response payload not delivered
Hello, An application is responding to his clients with an HTTP 422 error code and some small json data in body response. The ASM in front has been allowed to deliver the HTTP 422, but is not delivering the json content.
Any similar experience or advice how to handle this ? Thank you for any comment or share of experience
It almost sounds like the content-length header in the response is too short so the F5 is only reading the headers.
Maybe try to look at the request/response in a capture or enable response logging in ASM to see what the response looks like when it’s received?
Thanks a lot for your comment.
I have no direct access to the F5 unfortunately, but as far as i can test on a working environnement, the backend server seems to simply not crafting any JSON at all.
On the client page, a small window is expected JSON data, but it is having instead a 422 HTTP message, that to my understanding, could not contain any response data.
The application team was suspecting the F5 device to remove or replace any data that was being responded to the client. I have checked already that no stream or any other manipulation action was in place. I should have more details soon.
