The client might see Unknown error or Connection reset.
I think a change in 14.1.2 with an iRule that has specific coding is the cause but one of the Virtual servers affected for me is Exchange, where I’m using the Exchange2016 iapp, there are several iRules that the iapp creates.
Thanks for the response. Looking at the Exchange 2016 iapp, there is an irule with HTTP::redirect but it is the last action in the irule. Here’s the irule.
priority 900
if { ([HTTP::uri] == "/") } {
HTTP::redirect https://[HTTP::host]/owa/
I would expect F5 to update the Exchange iapp, if it were not compatible with 14.1.2, from the information in this support article it doesn’t appear that there is a problem.
HTTP iRule commands that inspect HTTP state after the commands HTTP::respond, HTTP::redirect and HTTP::retry will now return errors instead of returning corrupt data.
one example workaround is to move the HTTP::redirect to the last action in the irule.
It’s already the last action in this iRule. I don’t think this iRule is an example of a problem.
