http code 301&302
when using irule to redirect example: "HTTP::redirect https://[getfield [HTTP::host] “:” 1][HTTP::uri] "
i can see in the client that i get HTTP code 302 that means redirects, is there a way to get Permanent Redirect with HTTP 301 ?
thanks
Hi Shay,
You can specify the response code with HTTP::respond (Click here). Here is an example:
HTTP::respond  [content ] [ ]+
HTTP::respond 301 Location "https://[getfield [HTTP::host] ":" 1][HTTP::uri]"
Aaron
Here are a couple of examples:
This will take requests for mydomain.com/$uri and 301 to www.mydomain.com/$uri
switch -glob [string tolower [HTTP::host]] {
 "mydomain.com" {
  HTTP::respond 301 \
  "Location" "http://www.mydomain.com[HTTP::uri] " \
  "Server" "www.mydomain.com"
 This will 301 everone trying to access the /admin utilities to the homepage
switch -glob [string tolower [HTTP::uri]] {
 "/admin/*" {
  HTTP::respond 301 \
  "Location" "http://www.mydomain.com" \
