[HTTP CLASS] URI Path Flow Process
Hello Everybody, I’m wondering if the matching options of ann HTTPCLass applies only on actions related to redirection and sending to pool, or if it applies also to ASM routing; in other words, i would like to direct a /app URI in a particilar ASM policy for HTTP flows and /app2 in another policy which process JSON flows.
Could I use 2 HTTPClass With ASM enable, one for the /app and another for the /app2 ? I guess I could but I have a little doubt after checking the help menu on my F5.
yes, you can.
Wonderful !!
Thks a lot.
As Nitass said, you can add multiple HTTP classes to a virtual server. If you’re using ASM, you should make sure that a request will always match at least one HTTP class.
See SOL8018 for details:
sol8018: Overview of the BIG-IP HTTP class traffic flow 404 Page not found | BIG-IP Documentation
Aaron
Thks a lot, It works !
