HTTP Class Help
I am setting up HTTP Classes and have a configuration question. I have set the match only feature and then I have added hosts. What i am running into is I have to have 2 entries for the same host, one with www and one without( www.test.f5.com and test.f5.com) Is there a way to say match only the test.f5.com ?
Allan
Have you tried using an asterisk e.g. *test.f5.com
N
Looks like that works. Thanks
