HSTS - Header not inserted with iRule
Following is my iRule which is attached to $mydomain$ (http) VirtualServer in F5 for HSTS, but it is not inserting the “Strict-Transport-Security” header in the http response. When I run “curl -s -D- $mydomain$.com.au | grep Strict”, it doesn’t return anything. Am I missing something here? Please advise…
when HTTP_REQUEST { HTTP::respond 301 Location “https://[HTTP::host][HTTP::uri]” }
when HTTP_RESPONSE { HTTP::header insert Strict-Transport-Security “max-age=31536000” }
Thanks and regards.
Rana
Try this in your HTTP_RESPONSE event and then check the /var/log/ltm log.
foreach headerName [HTTP::header names] {
    append headerNames " |$headerName: [HTTP::header value $headerName]"
log local0. "$headerNames"
Are you attaching the HSTS response iRule to your HTTPS VIP? The HSTS header should only be sent via HTTPS.
Hi Guys… Thank you for your responses.
@ Eastman: I’ve added the bit you mentioned and following is how the iRule looks like. Still no luck and the log shows nothing.
iRule for HSTS HTTP Virtuals
foreach headerName [HTTP::header names] { append headerNames " |$headerName: [HTTP::header value $headerName]" }
log local0. “$headerNames”
@ bepsoccer: My understanding: I applied the iRule to http VS as the first line of the iRule is HTTP REDIRECT, so i didn’t apply the iRule to HTTPS VS. Please correct me if I am wrong.
Thanks guys, appreciate your help.
Rana
Hello,
As your http VS directly answer with a redirect, your HTTP_RESPONSE event is never triggered.
You should build your own irule in an HTTP_REQUEST event and use the following command instead :
HTTP::respond 302 noserver Location “https://www.domain.org” Strict-Transport-Security “max-age=31536000”
BR
Yann
Your Virtual server that is listening for HTTP should have one iRule :
set my_loc "https://[HTTP::host][HTTP::uri]"
TCP::respond "HTTP/1.1 301 Moved Permanently\r\nLocation: $my_loc\r\nConnection: close\r\nContent-Length: 0\r\n\r\n"
TCP::close
Your virtual server that is handing HTTPS has to have a client SSL profile and use a different iRule:
    HTTP::header insert "Strict-Transport-Security" "max-age=15552000; includeSubDomains"
If you are going to use HSTS your HTTP response should be 301 not 302. Also, the specification states that the HSTS header should only be sent by the HTTPS site.
Hi Guys,
It was my lack of understanding about how the iRules were triggering.
Both Yann and bepsoccer are correct, that HTTP_RESPONSE event was never triggered and needed to have the Separate iRule attached to https VS with the following .
when HTTP_RESPONSE { HTTP::header insert Strict-Transport-Security “max-age=15552000; includeSubDomains” }
Really appreciate your help guys.
Thank you
Rana
This can also be caused by Web Acceleration or manual use of iRule CACHE commands.
e.g. HTTP_RESPONSE will not fire on anything pulled from cache.
You can use CACHE_RESPONSE instead. I now use two rules and attach as appropriate.
    HTTP::header replace Strict-Transport-Security "max-age=31536000; includeSubDomains"
And,
when CACHE_RESPONSE {
    CACHE::header replace Strict-Transport-Security "max-age=31536000; includeSubDomains"
Recent versions have HSTS on the HTTP profile.
hey guys, may i know what is the difference between the following 2 lines?
HTTP::header replace Strict-Transport-Security “max-age=31536000; includeSubDomains”
HTTP::header insert Strict-Transport-Security “max-age=31536000; includeSubDomains”
