We are inserting an HSTS header using a policy (v 12). When a request comes into our virtual server, if the URI is just /, we have an iRule that will redirect the browser to a specific application. For example if the user goes to https://mysite.company.com, we send back a 302 redirect to /AppName/
A sample cURL session (with -I option) would look like this:
I can obviously abandon using the policy and insert the header before the redirect statement but I was trying to use a policy if possible. Is there a way to have the policy execute even after a redirect?
Originally, not all sites were ready to have the header inserted and as we share profiles, that would not work. Since all sites are now HTTPS, that could work but the question remains why the redirect seems to bypass the policy.
As your Irule on your http VS directly answer with a redirect (I Think that your policy is trigged in the RESPONSE event), your HTTP_RESPONSE event is never triggered because the redirect is trigged in the Request…
For this case you should build a specific Irule in an HTTP_REQUEST event and use the following command instead :
Actually, I tried a few things but I must be missing something. In v12, there is an HSTS option in the HTTP profile, but I verified that does NOT get inserted when doing a redirect either. When I went to the a valid page that returned 200, I did see my value of the HSTS header. I know as I made it an odd max-age to verify.
Can it really work this way that the only way to add an HSTS header when doing a redirect is to do it manually in the iRule?
BTW, there is no option in the profile to insert a response header—just a request header.
According to the documentation, HTTP_RESPONSE only fires for non-local data. Hence, a HTTP::redirect is local so this event does not fire. I had tried this but it does not work.
Concerning the processing order, you should note that the iRules are evaluated after the LTM policies: myF5
But the event order is also important, iRule based redirect will cause any response based action not to be fired.
So if you’re relying a lot more on the LTM policies, I suggest that you perform your redirects via policies as well, and include there the hsts header.
