HSL question
Hello!
Related to this topic:
~~DevCentral - An F5 Technical Community
Is there any way to configure that after HSL::send, the response data from the server will not be ignored?
Thanks!
you may consider sideband connection.
v11 iRules: Intro to Sideband Connections by Colin Walker
sideband wiki
Yes, I know. But I can only use v10…
is it http? if so, may HTTP::retry be useful?
But then, I think that the answer will be in different HTTP_RESPONSE event.
So, I guess there is no way in HTTP_REQUEST event send another http (or tcp) request and get the feedback as a part of the same event.
Anyway, thank you for your answer!
have you seen this example?
Conditioning iRule Logic on External Information - 01 - HTTP::retry by Deb Allen
Wow! Thank you a lot!!
It really can be a solution!
You make me happy! :slight_smile:
