Hi!
Wrote a logging iRule to log cache response headers with HSL. It works fine generally but some uris are pretty strange.
Here is the rule:
when HTTP_REQUEST priority 999 {
set host [string tolower [HTTP::host]]
set uri [HTTP::uri]
set hsl [HSL::open -proto UDP -pool syslog-514_pool]
when HTTP_RESPONSE {
if { [HTTP::header exists "Cache-Control"] } {
set CacheControl [HTTP::header "Cache-Control"]
set CacheControl " "
if { [HTTP::header exists "Expires"] } {
set Expires [HTTP::header "Expires"]
set Expires " "
HSL::send $hsl "[string map [list "\t \t" "\t-\t"]\
"<165>\t\
$Expires\t\
$CacheControl\t\
$uri\t\
$host\t\
"]\n"
Here is one of the lines that looks strange (note that this particular response did not have an Expires header):
Date Log Level Source IP Expires Max-Age URI Host
2014-04-11 08:08:36Local4.Notice10.0.0.1max-age=60, must-revalidate, publichttps://ourwebsite.com/directory/service.svc?query=stringourwebsite.com
We can’t seen the strange URI’s in the IIS logs. Could it be that the BigIP rejects it because the request is malformed? I am out of ideas.
/Patrik
