How use BIG-IP to capture HTTP request and response
Hi gurus,
I want to use BIG-IP Virtual Server (with HTTP profile) and capture full HTTP request and response. Can I do that? We can not debug on the Client and the real Server. Thanks
Phong
I would use tcpdump with relevant filters and then open the capture in wireshark. To capture full packet use -s0 and to output to a file use -w filename.
$ tcpdump -nni 0.0:nnnp -s0 -w /root/capture.pcap host 1.2.3.4
The p modifier is useful for capturing end to end traffic. More here and here.
Hello,
In fact you can use tcpdump but there is 2 problem with tcpdump :
1) If it is HTTPS, you will be forced to decrypted the traffic otherwise you will not view the request and response in clear text. 2) The second problem is that you must launched manually each time you want to capture traffic
My suggestion is to use irule to log all request and response header. This requires to have a VS with HTTP profile (Layer 7 VS “Standard”).
You have to add an irule that will look like this one
Code
set request "Client IP : [IP::client_addr] Host: [HTTP::host] [HTTP::method] [HTTP::uri]"
when HTTP_RESPONSE {
set response "Status: [HTTP::status] Content-Type: [HTTP::header "Content-Type"] Content-Length: [HTTP::header "Content-Length"] "
log local0. "Request --> $request Response --> $response"
I think that you can find many example of more complete “debug-irule” or you can adapt it to your need
Hope that this helps
Hi all,
I can use HTTP::collect & HTTP::payload to get full content HTTP::collect
But when I write to log by "log local0. “$payload”. It’s not enough content
May I write the $payload to a file on big-ip?
Phong
To capture request POST you can try this.
    if { [HTTP::method] equals "POST" } {
        catch { HTTP::collect [HTTP::header Content-Length] }
when HTTP_REQUEST_DATA {
    log local0. "[HTTP::payload]"
But I guess the option to troubleshoot for APM SSO, could be to use HTTPWatch or Fiddler.
Thank kunjan
I can not touch the Client and Server so I must do on F5. The “log local0. “[HTTP::payload]”” can not log full HTTP payload to logging
Phong
Thank kunjan
Phong
HI you can use irule example
code
    set REQUEST_RECEIVE [clock clicks -milliseconds]
    set uri [HTTP::uri]
    set clientip [IP::client_addr]
    set clientport [TCP::client_port]
    set RESPONSE_RECEIVE [expr {[clock clicks -milliseconds] - $REQUEST_RECEIVE}]
    log local0. "Server response took longer than ms: $RESPONSE_RECEIVE . TCP connection from [IP::client_addr]:[TCP::client_port] to [LB::server addr]:[LB::server port].Requested URI is ${uri}"
How about this:
  if {[HTTP::method] eq "POST"}{
     if {[HTTP::header "Content-Length"] ne "" {
       HTTP::collect 20000
 log local0. "payload is [HTTP::payload]"
