How to view IP/Interface List - LTM
Is there any way to view the interface to IP mapping on the GUI console of F5 LTM.
On clicking interaces, only interface names can be seen and on clicking self-ip, only IPs can be seen.
Thanks.
Please assist.
You’ll need two commands, b self list and b vlan list. I don’t think there is a direct map of self to interface.
Might be tricky in environments where a vlan is multiple interfaces, though. Maybe a console perl script to take care of this mapping for you?
In that specific case it would be valid to say that the self-ip is mapped to all interfaces in that vlan, so you should be covered there as well, no?
Try this:
!/usr/bin/perl
 use strict;
 my ($vlan);
 my (%int);
 my (%trunk);
 $b = '/bin/bigpipe';
 open cmd, "$b trunk list |" || die "error: $b trunk list";
 while (  ) {
         $vlan=$1 if (/^trunk\s+([^\s]+)\s+\{/i);
         $trunk{$vlan}=$1 if (/^\s+interface\s+(.+)/i);
 } close cmd;
 open cmd, "$b vlan list |" || die "error: $b vlan list";
 while (  ) {
         $vlan = $1 if (/^vlan\s+([^\s]+)\s+\{/i);
         $int{$vlan}=$1 if (/^\s+interfaces\s+(.+)/i);
         $int{$vlan}= "$1: $trunk{$1}" if (/^\s+trunks\s+(.+)/i);
 } close cmd;
 open cmd, "$b self list |" || die "error: $b self list";
 while (  ) {
         print "$1 = " if (/^self\s+([^\s]+)\s+\{/i);
         print "$1 ($int{$1})\n" if (/^\s+vlan\s+([^\s]+)/i);
 } close cmd;
Sample:
[root@ltm:Active] ~  perl hum
 10.10.10.10 = ext (1.3)
 11.0.0.40 = int (1.6)
 20.1.1.1 = tagged_vlan (tagged 1.2)
 1.1.1.2 = trunk_vlan (tr_test: 1.10 1.11)
 1:1:1:1:ffff:ffff:ffff:eeee = vlan6 (1.1)
Is that what you need?
Nice work, Hum! That’s where I was going, just didn’t get there fast enough…
