For one of the VIP below is the HTTP Send String I configured.
GET /portal/portaladmin/healthCheck HTTP/1.1\r\nHost: TEST.TEST.Ca\r\nConnection: Close\r\n\r\n
How to confirm what I am receiving in as receive string ? I need to set Receive String as 401. ? I used Curl and I see 401 is showed up ( marked Black ). So is it that I only need to write 401 in the Receive String of Monitor ?
2nd question I need to set multiple monitor for different services configured on same server. How to set multiple send string from a single Monitor Configuration. ? Let say if I am configuring 2 send string and 2 corresponding receive string how to set that when both of the String Condition need to be True as a condition to mark the VIP live. ?
[admin@F5:Active:In Sync] ~ # curl -vk https://test.test.ca/portal/portaladmin/healthCheck
* About to connect() to test.test.ca port 443 (#0)
* Trying 10.8.16.62… connected
* Connected to test.test.ca (10.8.16.62) port 443 (#0)
* successfully set certificate verify locations:
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* SSLv3, TLS handshake, Client hello (1):
* SSLv3, TLS handshake, Server hello (2):
* SSLv3, TLS handshake, CERT (11):
* SSLv3, TLS handshake, Server key exchange (12):
* SSLv3, TLS handshake, Server finished (14):
* SSLv3, TLS handshake, Client key exchange (16):
* SSLv3, TLS change cipher, Client hello (1):
* SSLv3, TLS handshake, Finished (20):
* SSL connection using DHE-RSA-AES256-GCM-SHA384
* Server certificate:
* subject: C=CA; ST=ns; L=Halifax; O=Nova Scotia Power Inc; OU=IT; CN=test.test.ca
* start date: 2019-04-17 00:00:00 GMT
* expire date: 2021-04-21 12:00:00 GMT
* subjectAltName: test.test.ca matched
* issuer: C=US; O=DigiCert Inc; CN=DigiCert SHA2 Secure Server CA
* SSL certificate verify ok.
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/1.0.1l zlib/1.2.3 libidn/1.18
> Host: test.test.ca
> Accept: */*
< HTTP/1.1 401 Unauthorized
< Content-Type: text/html
< Server: Microsoft-IIS/10.0
< WWW-Authenticate: Negotiate
< WWW-Authenticate: NTLM
< X-Powered-By: ASP.NET
< Date: Mon, 05 Aug 2019 18:41:27 GMT
< Connection: close
< Content-Length: 1293
< Vary: Accept-Encoding
<!DOCTYPE html PUBLIC “-//W3C//DTD XHTML 1.0 Strict//EN” “http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd”>
<html xmlns=“http://www.w3.org/1999/xhtml”>
<head>
<meta http-equiv=“Content-Type” content=“text/html; charset=iso-8859-1”/>
<title>401 - Unauthorized: Access is denied due to invalid credentials.</title>
<style type=“text/css”>
body{margin:0;font-size:.7em;font-family:Verdana, Arial, Helvetica, sans-serif;background:#EEEEEE;}
fieldset{padding:0 15px 10px 15px;}
h1{font-size:2.4em;margin:0;color:#FFF;}
h2{font-size:1.7em;margin:0;color:#CC0000;}
h3{font-size:1.2em;margin:10px 0 0 0;color:#000000;}
header{width:96%;margin:0 0 0 0;padding:6px 2% 6px 2%;font-family:“trebuchet MS”, Verdana, sans-serif;color:#FFF;
background-color:#555555;}
#content{margin:0 0 0 2%;position:relative;}
.content-container{background:#FFF;width:96%;margin-top:8px;padding:10px;position:relative;}
</style>
</head>
<body>
<div id=“header”><h1>Server Error</h1></div>
<div id=“content”>
<div class=“content-container”><fieldset>
<h2>401 - Unauthorized: Access is denied due to invalid credentials.</h2>
<h3>You do not have permission to view this directory or page using the credentials that you supplied.</h3>
</fieldset></div>
</div>
</body>
</html>
* Closing connection #0
* SSLv3, TLS alert, Client hello (1):
