How to use irules to do SIP outbounding proxy?
Hi, everyone
I am trying to do SIP proxy server loadbalance. By now, we can do loadbalance for inbound SIP request, I mean , from the client to the proxy server , just using SIP persistant.
The problem is, when the proxy serverA send outbound SIP request to the remote SIP serverC with one call-ID,the remote SIP serverC response packet is to the inbound virtual server with the same call-ID. But our bigip fail to send this response back to serverA ,since there is no SIP persistant information for this call-ID.
So, can we use irules to write one new persistant information at our SIP persistant table when serverA to send outbound SIP packet? I mean , when ServerA to send outbound SIP packet, we use irules to write one persistant information, call-ID and the serverA IP (Souce IP).So when the response packet back , bigip can found at persistant table, and send the responce back to serverA.
Thanks,
Raymond
We are looking at it, please stay tuned, thanks for the patience
I haveing the same problem, do you have any update on this please.
Thanks,
Raghu
Can you post your rule, any relevant logs and a description of the issue you’re seeing?
Any updates to this?
//s
Any updates to this? My network requires the same functionality.
Thanks!
Paul
I think session command with keyword “any” may help.
call-id can be detected on the returning traffic by iRule and session command can be used to save persistence record, for example,
session add uie [list $sessionid any] [list [IP::remote_addr] 5555] $::sessionTimeout
(keyword “any” allows this record to be used by any virtual server)
I am not sure if the record that is being added by session command can be used by normal call-id persistence or not. (probably need to use appropriate syntax for address/port I guess) however, we can use “session lookup” command to lookup for the existing record also.
Did you make this work?
We do something similar and have found out some things that can be good to know for anyone trying to load balance sip.
For me it felt natural to use mode because I was working with sip but that did not work together with keyword any
Example
On vs_1
session add sip [SIP::call_id] [LB::server addr] 180
session add uie [SIP::call_id] [LB::server addr] 180
On vs_2
session lookup sip “[SIP::call_id] any virtual”
This do not get back the stored value
session lookup uie “[SIP::call_id] any virtual”
But this do..
Simply use uie instead of sip, but it is strange that it did not work with mode sip.
Another thing that can be confusing is that when you choose a sip profile in your vs you will get the SIP::call_id as persistence value even though you choose None as your Default Persistence Profile. I’m not sure this make a different but we created a SIP persistence profile that never match and used that insted. With this we only have the values we set and want to use.
All this is valid for 9.4.3, I do not know if it is updated in any hotfix or in 9.4.4. Does anyone know?
Sorry, I haven’t tried with “sip” option, I use uie and it works as well
I saw the same thing.
When you use session commands, don’t use sip mode because it doesn’t seem able to share the session data with another vs.
use another mode.
Hi
Could you please share your rule?
zafer
here is something that helped me:
when SIP_REQUEST {
pool mypool
set id “[persist lookup sip [SIP::call_id]]”
log local0.alert “ID found in lookup is: $id”
if { [llength $id] } {
log local0.alert “In if select pool”
return
set id “[SIP::call_id] any virtual”
set sessionInfo [session lookup uie $id]
log local0.alert “Session information found is: $sessionInfo”
if { [llength $sessionInfo] } {
log local0.alert “Choosing member acording to session info”
pool mypool member $sessionInfo
Has anyone successfully gotten this to work? If so, can you post your solution, please?
I am trying to achieve SIP session based load balancing using LTM while server is acting as B2BUA.
The call flow that I would like to load balance is as following:
a. client A sends SIP request to LTM. LTM picks up Server X to forward request to.
b. Server X forwards request back to LTM to deliver SIP request to client B.
c. Client B send SIP response to LTM. LTM need to forward thus received SIP response to Server X.
d. Server X forwards back SIP response to LTM to deliver SIP response to client A.
Similarly, when a new SIP request is initiated by Client B then LTM forwards it to Server Y (based on least connections being used) and rest of call flow is same as above.
I started of trying to achieve the above call flow by using the iRules provided by you. I added couple of iRules for SIP_RESPONSE event (very similar to your iRules for SIP_REQUEST event) for outgoing (to add to session) and in incoming (lookup for session).
But I am running into issues with handling of SIP_RESPONSE events:
a. I do not think SIP_RESPONSE event is invoked during outgoing. LTM seems to be dropping SIP response packet received from Server.
b. I see TCL error thrown by LTM while processing SIP_RESPONSE event invoked during incoming. But I do see the SIP response packet getting delivered to Server. Find below generated TCL error:
Prerequisite operation not in progress line 4 invoked from within session lookup uie [SIP::call_id] any virtual
Thanks Nat for your response. Your suggestion of checking for which side of context iRule help me understand what is happening a little more.
We are using version 9.4.6.
The incoming virtual server uses following two iRules:
sip_in
sip_in_2
The outgoing virtual server uses following two iRules:
sip_out
sip_out_2
Find below iRules mentioned above.
iRule sip_in:
when SIP_REQUEST {
pool sip
log local0. “clientside = [clientside]”
logic to use appropriate pool
pool sip
return
set sessionInfo [session lookup uie “[SIP::call_id] any virtual”]
pool sip
return
iRule sip_in_2:
when SIP_RESPONSE {
pool sip
set clientside [clientside]
if { $clientside == 0 }
log local0. “call id: [SIP::call_id]”
log local0. “From: [SIP::from]”
log local0. “To: [SIP::to]”
log local0. “Method: [SIP::method]”
log local0. “Response: [SIP::response code] [SIP::response phrase]”
return
set abcd “[SIP::call_id] any virtual”
set id “[persist lookup sip $abcd]”
log local0.alert “ID found in persist lookup is: $id”
pool sip
return
pool sip
return
iRule sip_out:
when SIP_REQUEST {
pool sip
session add uie [SIP::call_id] [IP::client_addr] 3600
forward
iRule sip_out_2:
when SIP_RESPONSE {
pool sip
forward
After putting check for which side of context iRules is at the moment. I observed following:
a. When a new SIP request comes into LTM from Client 1. LTM uses sip_in iRule and forward it to Server instance 1.
b. Then Server processes on that SIP request for forward it to deliver to client 2 through LTM. At this point sip_out iRule is hit.
c. Then client 2 responds then sip_in_2 iRule is hit (with clientside context). Per sip_in_2 IRule LTM forwards thus received SIP response to Server instance 1.
d. Then Server processes on that SIP response and forward it to be delivered to client 1. At this point sip_in_2 iRule is hit (with serverside context!!!).
Can you help me understand why sip_in_2 is hit instead of sip_out_2 in d above?
one quick answer/guess about why sip_in_2 is hit is…
by default, BIG-IP create connection table for UDP traffic. and if return packet match existing connection table, bigip will treat that return packet as it belongs to previous created connection.
you may use packet trace to verify if 4-tuple match existing connection table or not.
use command line as examples below to see connection table
b conn
b conn show all
b conn client 1.2.3.4 show all
you may combine sip_in/sip_out irule together
or
you may try custom UDP profile with immediate timeout. in that case, bigip will not create connection table.
hope this helps,
Nat
Thanks Nat for your suggestion.
That make it work as desired for UDP.
In SIP transport protocol used could be either UDP or TCP. SIP stack switches transport mode from UDP to TCP when packet size is greater than MTU. Therefore, I have created virtual server for both UDP and TCP in both directions (incoming & outgoing).
After making custom UDP profile with immediate timeout I see all the packets hittng right iRule at the right time. But when sip stack switches transport mode from UDP to TCP, I observe recurrence of similar behvior in which sip_out_2 is bieng hit in serverside.
Is there some means to customize TCP profile to achieve the same effect.
you cannot use the same technique for TCP. I believe changing some SIP parameters on server may help. (I might be wrong)
May I ask more information
- does server is configured to use bigip as SIP proxy?
- does bigip snat traffic to server?
- what is destination IP in step d (packet from server to bigip?)
It would be great if you can post packet trace.
Thanks,
Nat
