Overview
You can use the F5 image generator ( F5 BIG-IP Image Generator Tool ) to create BIG-IP images for use in public Clouds. This method creates a private machine image and is therefore not limited to the official BIG-IP versions released via the marketplace.
The F5 image generator comes as a multi-component install, or as a docker container.
This document shows the steps required to generate a functional private image with the docker method within both AWS and Azure.
Common Prerequisite
- Open Virtualization Format Tool (ovftool) – Download from VMware
- Working docker environment
- BIG-IP ISO (with optional EHF ISO)
- Optional hardware virtualization support ( GitHub - f5devcentral/f5-bigip-image-generator: Generate custom images for F5 BIG-IP. · GitHub )
AWS
You can provision a Ubuntu (all major Linux distros should work with the container method) host using i3.metal instance type – this instance type is the cheapest with hardware virtualisation support. The presence of hardware virtualisation speeds up the image creation process, but it is not essential.
Ensure the root device has enough disk space (e.g., 100 GB) – this is needed to hold all files the image creation process requires
You can also use an existing host, provided it has docker installed and has enough disk space.
Once the host is ready, go through the following steps as a reference.
cd /home/ubuntu
Get ovftool onto the host (need to download from VMware first). Below is an example of getting it via curl.
curl -OJ https://cz-abgmbh.s3.amazonaws.com/VMware-ovftool-4.4.3-18663434-lin.x86_64.bundle
Install ovftool and copy extracted files to local directory
chmod +x VMware-ovftool-4.4.3-18663434-lin.x86_64.bundle
sudo ./VMware-ovftool-4.4.3-18663434-lin.x86_64.bundle --eulas-agreed
sudo cp -r /usr/lib/vmware-ovftool /home/ubuntu/vmware-ovftool
Get BIG-IP ISO and optional EHF ISO
curl -OJ https://cz-abgmbh.s3.amazonaws.com/BIGIP-15.1.5-0.0.10.iso
Run below to obtain/run the container, enable hardware virtualisation support and mount local directory into the container
sudo docker run -it --device="/dev/kvm" -v "/home/ubuntu:/mnt" f5devcentral/f5-bigip-image-generator:latest
Inside the container, run the following
cp -r /mnt/vmware-ovftool /usr/lib/vmware-ovftool/; sudo chmod +x /usr/lib/vmware-ovftool/ovftool /usr/lib/vmware-ovftool/ovftool.bin;
PATH=$PATH:/usr/lib/vmware-ovftool/:/f5
which ovftool
Create config.yml file for the image generator. Check GitHub - f5devcentral/f5-bigip-image-generator: Generate custom images for F5 BIG-IP. · GitHub for all options
cat << EOF > config.yaml
AWS_ACCESS_KEY_ID: "xxx"
AWS_SECRET_ACCESS_KEY: "xxx"
AWS_BUCKET: "cz-abgmbh"
AWS_REGION: "us-east-1"
BOOT_LOCATIONS: "1"
MODULES: "all"
PLATFORM: "aws"
REUSE: "Yes"
ISO: "/mnt/BIGIP-15.1.4.1-0.0.15.iso"
EOF
The image generator creates the image from the ISO and then uploads it to an existing s3 bucket, after which the image is converted into a snapshot, which is eventually registered as an AMI.
The AWS key must carry the appropriate permissions. See this ( VM Import/Export Requirements - VM Import/Export ) for detail.
As well as a service role named ‘vmimport’ be created. See this ( VM Import/Export Requirements - VM Import/Export ) for detail.
Once all the permissions and the role are ready, run the build process as below.
build-image -c config.yaml
The process will generate the image, upload it to the s3 bucket, convert it to a snapshot and print out an AWS AMI ID.
Azure
To generate the image for Azure, the process is that the image generator creates the image, uploads it to an existing storage container, it will then convert that image to an Azure image and place it within the same Azure resource group where the existing storage container is.
A service principal is required with ‘Contributor’ role assignment.
Refer to this ( f5-bigip-image-generator/docs/providers/azure at master · f5devcentral/f5-bigip-image-generator · GitHub ) for detail.
Below is a sample config.yaml file.
AZURE_APPLICATION_ID: "xxx"
AZURE_APPLICATION_SECRET: "xxx"
AZURE_REGION: "Australia East"
AZURE_RESOURCE_GROUP: "xxx"
AZURE_STORAGE_CONNECTION_STRING: "xxx"
AZURE_STORAGE_CONTAINER_NAME: "xxx"
AZURE_SUBSCRIPTION_ID: "xxx"
AZURE_TENANT_ID: "xxx"
BOOT_LOCATIONS: "1"
MODULES: "all"
PLATFORM: "azure"
REUSE: "Yes"
Hope the processes described in this article make it easier for people getting the image up and running in AWS and Azure. GCP should be very similar, please leave a comment if you are having issues with GCP and I will take a look as well.
