Hi Anyone How to use F5 Bigip(v11.4) to detect pool member’s CPU and Disk utilization? Pool member is LinuxOS. If pool member’s CPU or Disk utilization up to 70 percent. F5 Bigip change the pool member active to disable. What good method? Many thanks. LEE
You’ve a few options. If these are HTTP boxes you could perhaps run a script creates a HTML page containing the CPU figure and use a HTTP monitor to ‘read’ it.
Perhaps the SNMP monitors might be useful too.
You could also use an external monitor to call a script that queries the CPU somehow.
I’d suggest you take a look at the Monitors Reference here: BIG-IP Local Traffic Manager: Monitors Reference
