Before I run the event daemon on the BIG-IP in debug mode
I have deployed webservice on one machine"10.0.1.34",then
I run my subscription on another machine"10.0.1.33",and return the subscriptionID"A8A986D9-1974-6756-6247-0150A07139C2"
then I run the event daemon on the BIG-IP in debug mode
Some logs are as follows:
processSOAPMessage()
ns: urn:iControl:Management/EventSubscription
Destroying Consumer 78186C0A-1974-7CB7-0E51-579E7D94E3E3
Saving Consumer list
******** Begin Memory Dump ********
Total Memory Used By Subscriptions: 0 Bytes
******** End Memory Dump ********
Creating Consumer E263EDF9-1974-ABEA-9046-B0D7A2B7442B
Received TRANSACTION!
MCPSerializer::serialize - operation 2908 (modify); object 2122(db_variable)
MCPSerializer::addData(), db_variable_name : string
MCPSerializer::addData(), db_variable_value : string
adding event to consumer E263EDF9-1974-ABEA-9046-B0D7A2B7442B
MCPSerializer::serialize - operation 2908 (modify); object 944(pool_member)
MCPSerializer::addData(), pool_member_pool_name : string
MCPSerializer::addData(), pool_member_addr : ip_address
MCPSerializer::addData(), pool_member_port : service
MCPSerializer::addData(), pool_member_monitor_status : ulong
MCPSerializer::addData(), pool_member_session_status : ulong
Consumer E263EDF9-1974-ABEA-9046-B0D7A2B7442B: overhead 1471 bytes
List[000] - Attrs: {48,22}; Total: 78 bytes
List[001] - Attrs: {32,29,22,31,31}; Total: 153 bytes
List[002] - Attrs: {33,29,24,31,31}; Total: 156 bytes
List[003] - Attrs: {37,29,24,31,31}; Total: 160 bytes
List[004] - Attrs: {38,29,21,31,31}; Total: 158 bytes
List[005] - Attrs: {32,29,22,31,31}; Total: 153 bytes
List[006] - Attrs: {32,29,24,31,31}; Total: 155 bytes
List[007] - Attrs: {37,29,24,31,31}; Total: 160 bytes
List[008] - Attrs: {46,31}; Total: 85 bytes
List[009] - Attrs: {48,22}; Total: 78 bytes
Total Memory: 2807 bytes
Total Memory2: 3688 bytes
Total Memory Used By Subscriptions: 2807 Bytes
Processing consumer: ‘E263EDF9-1974-ABEA-9046-B0D7A2B7442B’
+ objects: 10; time (t0,t1,delta): (1181017792, 1181017792, 0)
Exiting MCPSubscriber Thread…
SOAPException on notification attempt: Timed out waiting for socket read.
+ objects: 10; time (t0,t1,delta): (1181017792, 1181017817, 25)
for what reason there is a SOAPException:SOAPException on notification attempt: Timed out waiting for socket read.
another question: The value of min_events_per_timeslice should i set what?
