hi
i am writing a iapp including iall. so i must use tmsh command to create a icall script.
i use a variable (icall_script_name) as the script name, and i use another variable(icall_script_Get_HDP_Ips) as the script. The command is:
tmsh::create sys icall script ${icall_script_name} ${icall_script_Get_HDP_Ips}
but i get the error information: 010715bd:3: The parent folder is owned by application service (/Common/asfdsdf.app/asfdsdf), the object ownership cannot be changed to ().
Anyone can help me ?
Thanks you very much.
Ruiqiang Lu
