How to unset custom value on a resource?
Hi All,
Trying to work out how, via the REST API, I would unset a custom value on a resource, permitting the default profile’s value to take effect.
Everything I’ve tried so far is not effective.
Set a custom value, in this case a cipher string:
f5unit.modify("/ltm/profile/client-ssl/~TEST~test1", {"ciphers": "!EXPORT:!DH:!MD5:!SSLv3:RSA+AES:RSA+3DES:!RSA+RC4:ECDHE+AES:ECDHE+3DES:ECDHE+RSA:@SPEED"})
Unset the value:
f5unit.modify("/ltm/profile/client-ssl/~TEST~test1", {"ciphers": None})
From the WebUI, this results in the “Cipher” custom checkbox being checked, but with no value.
How do i set a resource to inherit the default profile’s value?
Thanks.
Seems like there is no way to reset fully by using RestAPI. The closest I could do was
f5unit.modify("/ltm/profile/client-ssl/~TEST~test1", {"ciphers": "DEFAULT"})
Yes, still the check box is enabled. But I guess this is same as inherit from the parent profile.
Thanks. Hopefully there is a way to do a reset but this will definitely work in the mean time.
I believe DEFAULT is a reserved word for ciphers which give you a list of LTM defaults rather from the profile which it inherits its defaults from. Seems we have the same question, but trying to administer differently. DevCentral - An F5 Technical Community
