I configured syslog-ng on the F5 LTM (10.2.1) to send system related log entries and iRule generated logs to a remote server. However, I do see many uneeded log entries that I want to avoid going to the log server - For example “info logger” type of entries - See example below. If you can help shed some light on how to avoid sending such log entries, and better customize syslog-ng to send in only system errors, it would be great -
-- On the F5 LTM, I see the following proccess running ( 2 of them)
Here is more information about the httpd logs - I was able to disable these log entries from being written to the their respective log files via syslog-ng on the F5 LTM (via commenting out the destination log directory in the syslog-ng config file, for example:
destination (/var/log/httpd/ssl_access_log) …
Entries below are currently still going to the remote syslog server, and I am looking to see if there is a way to disable that if possible.
-- Thanks for pointing the article, I came across it during my research as well - Here is the configuration I tried - (Note, I narrowed down my log level to warnings and higher)
[root@HOSTNAME:/:Active] config b syslog include
SYSLOG - Include Data:
destination remote_server {
udp(“x.y.z.w” port (514));
local0.* /var/log/ltm
filter f_local0 {
facility(local0) and level(warn..emerg);
filter f_no_audit {
not match(“AUDIT”);
destination d_ltm {
file(“/var/log/ltm” create_dirs(yes));
log {
source(local);
filter(f_local0);
filter(f_no_audit);
destination(d_ltm);
destination(remote_server);
-- Still seeing "info logger, also I am seeing “crond”, “snmpd” entries sent to the remote syslog server.
-- I am trying to see if there are any syslog-ng filters which would avoid such entries (above) from going to the remote syslog server. Basically, better optimimization filtering options for syslog-ng. Currently, it is sending a lot of unwanted information via syslog (udp:514) such as log entries above.
