Hi all,
I was just wondering how to trigger the discover process of an OAuth provider via TMSH or the REST API.
I see a pull-config option in tmsh, but it doesn’t appear to do anything?!?
modify apm aaa oauth-provider provider_test pull-config
Can anyone help?
Regards,
Simon
Just wanted to post the solution I found
After creating the OAuth provider, you can create the OIDC discover config
create mgmt tm access oidc discover providerName mytest_provider
Eljay
3
Hi, did you ever find a solution for doing this with REST API?
