Hi Experts
How do I track a pool member status from i-call script? Pool-1 has nodes, node-1 and node-2. I need to track node-1 status and take action so that I can shut down another node in a different pool. I can not track only node since it can not be health checked by TCP/HTTP. Only ICMP health checks are not enough to give real status of App nodes. So I have to track individual pool member.
Will the below work or need to be edited more?
sys icall script /Common/down_event {
app-service none
definition {
This script is triggered via alertd and will only trigger when a pool member is DOWN
Node 1 status
set dev_objs [tmsh::get_status /ltm pool /Common/pool-1 member /Common/node-1:80]
foreach dev_obj $dev_objs {
set STATUS_1 [tmsh::get_field_value $dev_obj "status.availability-state"]
"If node-1 is down, disable another node NODE-1 as well"
tmsh::log " $STATUS_1"
if {($STATUS_1 == "Offline")}{
node reported as down
tmsh::log "Node-1 for pool-1 is down. DISABLING NODE-1 in pool-2"
tmsh::modify /ltm node NODE-1 state user-down
