How it’s possible to test bandwidth between BIG-IP and other network equipment ?
Used tools like iperf or ttcp.
Is it supported to install this in BIG-IP ?
Best regards
Best regards
I don’t think you can install 3rd party software/tools without invalidating contract with F5. Why do you need to test bandwidth if it is in the same DC (assuming so) as you would have completed control over the cabling on both ends ?
