How to sperate BIND View on GTM by Listener?
HI Every one. I’ve a task to implement GTM to replace 2 DNS Server (Internal DNS Server and External DNS Server) I’ve export the zone file of both dns server and import it to GTM on seperate View. And then i create 2 Listener on 2 VLANS for serve the DNS query. So. My requrirement is.
  • When DNS Query come to Internal Listener, It’s should query only Internal BIND View.
  • And When DNS Query come to External Listener, It’s should query only External BIND View.
I’ve try to config ACL on view of named.conf by statement “match-destinations” with Listener IP but it didn’t work cause GTM call to Local Bind by loopback ip. So could you please suggest me which way to work on this requirement. Thanks in advance.
Prachachart.S
iRules-based solutions:
A solution more along the lines of your effort:
