How to set 'Traffic Class' to a LocalLB::VirtualServer
How can I set/get ‘Traffic Class’ to a LocalLB::VirtualServer. whats the API calls availble in iControl to achieve the same. I am using pycontrol * iControl APIs. can somebody help me out
Basically I am trying to modify an existing virtual server by adding a Traffic Class into it. I want to know how to achieve this using an iControl API . I am trying on versions v11.1.0 & v10.2.3.
I didn’t find an API either for setting this or getting the traffic class added?
Thanks,
Vipin
Hi Vipin, sorry it took so long to get back to you. I don’t see the interface in there either. I’m double checking with PD to see if there was a reason for it’s omission and when it’s scheduled to be released. I’ll let you know what I find out.
Any update on this?
I just checked and there doesn’t appear to be any way to access any information on Traffic Classes via iControl.
LocalLB or LocalLBVirtualServer
