Hi I am trying to create persistence profile with the following parameters, Using Powershell
Method: Insert SessionCookie: False ExpirationMinutes: 60
After going through the API details, I found the class iControl.LocalLBCookiePersistenceMethod I am using following code to set the value, However its giving error “Property ‘value’ cannot be found on this object; make sure it exists and is settable.” for the code highlighted in bold. Can anybody tell me whether I have selected correct class and how can we set the Cookie method to Insert?
{ Param( [string] $profileName ); $profiles = (, $profileName); $PersistanceArray = @() $PersistanceArray = (Get-F5.iControl).LocalLBProfilePersistence.get_list() If ($PersistanceArray -contains $profileName) { Write-Host “Persistance Profile: $profileName already exists” -ForegroundColor Cyan $res = @() $res=(Get-F5.iControl).LocalLBProfilePersistence.get_default_profile($profileName); foreach ($i in $res) {Write-Host $i.value}
} Else {
try {
$mode = New-Object -TypeName iControl.LocalLBPersistenceMode;
$mode ="PERSISTENCE_MODE_COOKIE";
$modes=(,$mode)
(Get-F5.iControl).LocalLBProfilePersistence.create($profiles,$modes);
Write-Host "Persistance Profile: $profiles created";
$method1 = New-Object -TypeName iControl.LocalLBCookiePersistenceMethod;$method1.value =1;“COOKIE_PERSISTENCE_METHOD_INSERT”; $methods=(,$method1);(Get-F5.iControl).LocalLBProfilePersistence.set_cookie_persistence_method($profiles,$methods);
$cookieName = New-Object -TypeName iControl.LocalLBProfileString;
$cookieName.value = "cookie-Xy";
$cookieName.default_flag = "false";
$cookieNames = (, $cookieName);
(Get-F5.iControl).LocalLBProfilePersistence.set_cookie_name($profiles,$cookieNames);
$time = New-Object -TypeName iControl.LocalLBProfileULong;
$time.value=600;
$time.default_flag = "false";
$times=(,$time);
(Get-F5.iControl).LocalLBProfilePersistence.set_cookie_expiration($profiles,$times);
} catch {
Write-Host "There was an exception thrown creating Persistance Profile: $profileName" -ForegroundColor Red
$Error[0]
