am using the perl toggel script to enable disable a member in a pool with perl.
Below is a code snippet in perl for function disable pool member
sub disablePoolMember()
my ($pool_name, $member_def) = (@_);
Split apart node:port
($sNodeIP, $sNodePort) = split(/:/, $member_def, 2);
if ( “” eq $sNodePort )
$sNodePort = “0”;
$member = { address => $sNodeIP, port => $sNodePort };
Query enabled state for given Node:port
$pool_member_state = &getPoolMemberState($pool_name, $member);
Set the state to be toggled to.
my $toggleState = “STATE_DISABLED”;
my $toggleState1 = “AVAILABILITY_DOWN”;
if ( “STATE_DISABLED” eq $pool_member_state )
$toggleState = “STATE_ENABLED”;
print "$cus_time : ";
print “Pool Member $sNodeIP is aleady in Disabled state. No Action taken.\n”
elsif ( “STATE_ENABLED” eq $pool_member_state )
else
die(“Couldn’t find member $member_def in pool $pool_name\n”);
$MemberSessionState =
member => $member,
session_state => $toggleState,
monitor_state => $toggleState
push @MemberSessionStateList, $MemberSessionState;
push @MemberSessionStateLists, [@MemberSessionStateList];
Enable the state.
$soapResponse =
$PoolMember->set_session_enabled_state
SOAP::Data->name ( pool_names => ( [$pool_name] ) ),
SOAP::Data->name ( session_states => [@MemberSessionStateLists] )
&checkResponse($soapResponse);
print “Pool Member $pool_name {$sNodeIP:$sNodePort} state set from ‘$pool_member_state’ to ‘$toggleState’\n”;
Am trying to set option "Forced Offline (Only active connections
allowed)".
Am setting monitor_State above but it does no select that option when verified in UI.
How can make so it select “Forced Offline” instead of “Disabled”
Any help is greatly appreciated.
Ven.
