how to send NXDOMAIN with BigIP DNS
Hi friends,
I have a question. A customer would like to manipulate some DNS responses using F5 DNS having the following use cases:
  1. Change the DNS Response IP (to a public IP)
  2. Change the DNS Response to NXDOMAIN (for IP addresses which should not be published)
I thought about the following iRule to create the 1st use case:
when DNS_REQUEST {
if { [DNS::question name] equals “fqdn.of.customer” }{
DNS::answer insert “[DNS::question name]. 3600 [DNS::question class] [DNS::question type] 1.2.3.4”
DNS::return
Any idea what I have to use to return a NXDOMAIN?
DNS::answer insert “???”
Do you see a simpler approach? (mid Term we will implement different DNS views).
Thanks,
Rolf
After searching a while i found the correct iRule statements:
DNS::answer clear
DNS::header rcode NXDOMAIN
DNS::return
