Hi Team,
how i will check that SSLv3 is disable or not on my F5 box
Firmware version is 11.5.1
Hi Team,
Local Traffic → Profiles → Client-SSL → YourSSLProfileName
Check under advanced settings, if Cipher configuration is
DEFAULT
, then SSLv3 is disabled (because your BigIP version is v11.5.1)
This SOL lists out the SSL/TLS versions and cipher suites in the DEFAULT string per BigIP version: 404 Page not found | BIG-IP Documentation
If you want to be sure, you can use the openssl tool to attempt to establish a session using SSLv3:
openssl s_client -connect devcentral.f5.com:443 -ssl3
- replace ‘devcentral.f5.com’ with your website FQDN.
You should receive a SSL handshake error similar to the one below. However, if you get a
Session Established
response, SSLv3 is enabled.
CONNECTED(00000003)
4294956672:error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure:s3_pkt.c:1472:SSL alert number 40
4294956672:error:1409E0E5:SSL routines:ssl3_write_bytes:ssl handshake failure:s3_pkt.c:656:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 0 bytes
