Inserting cookie: PHPSESSID=eur026tal67g54keu6oj5gphh6; expires=Fri, 08-May-2015 13:23:10 GMT; path=/; domain= HttpOnly
Need code to strip “HttpOnly” or “httponly”
HTTP::header insert “Set-Cookie” $cookielist($cookiename)
doesn’t HTTP::cookie httponly work?
HTTP::cookie
configuration
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.24.10:80
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
http { }
tcp { }
rules {
qux
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 4
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
members {
200.200.200.101:80 {
address 200.200.200.101
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
when HTTP_RESPONSE {
HTTP::cookie httponly PHPSESSID disable
trace
[root@ve11c:Active:In Sync] config ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.24.8(53626) <-> 172.28.24.10(80)
1431064577.3957 (0.0016) C>S
HEAD / HTTP/1.1
User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/1.0.1l zlib/1.2.3 libidn/1.18
Host: 172.28.24.10
Accept: */*
New TCP connection 2: 200.200.200.14(53626) <-> 200.200.200.101(80)
1431064577.3977 (0.0009) C>S
HEAD / HTTP/1.1
Host: 172.28.24.10
Accept: */*
1431064577.4007 (0.0029) S>C
HTTP/1.1 200 OK
Date: Fri, 08 May 2015 05:37:12 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Sun, 09 Feb 2014 08:39:51 GMT
ETag: "41879c-59-2a9c23c0"
Accept-Ranges: bytes
Content-Length: 89
Set-Cookie: PHPSESSID=eur026tal67g54keu6oj5gphh6; expires=Fri, 08-May-2015 13:23:10 GMT; path=/; domain=www.supportourtroopscanada.com.; HttpOnly
Content-Type: text/html; charset=UTF-8
1431064577.4008 (0.0050) S>C
HTTP/1.1 200 OK
Content-Length: 89
I am creating new cookies. At the end of the line, a string “HttpOnly” or “httponly” is added and unable to create the cookie. I wanted to string the string “HttpOnly” or “httponly” out of the cookie line.
Under is the code and if you look at “Inserting cookie” portion, it is not inserting the code.
when HTTP_RESPONSE { if { $static::ProxyPassDebug > 1 } { log local0. “$log_prefix: [HTTP::status] response from [LB::server]” }
if {$bypass} {
No modification is necessary if we didn't change anything inbound so disable the stream filter if it was enabled
Check if we're rewriting the response
if {$static::RewriteResponsePayload} {
log local0. "$log_prefix: Rewriting response content enabled, but disabled on this response."
Need to explicity disable the stream filter if it's not needed for this response
Hide the command from the iRule parser so it won't generate a validation error
when not using a stream profile
set stream_disable_cmd "STREAM::disable"
Execute the STREAM::disable command. Use catch to handle any errors. Save the result to $result
if { [catch {eval $stream_disable_cmd} result] } {
There was an error trying to disable the stream profile.
log local0. "$log_prefix: Error disabling stream filter ($result). If you enable static::RewriteResponsePayload, then you should add a stream profile to the VIP. Else, set static::RewriteResponsePayload to 0 in this iRule."
Exit from this event.
return
Configure and enable the stream filter to rewrite the response payload
if {$static::RewriteResponsePayload > 1} {
set stream_expression_cmd "STREAM::expression \"@$host_serverside$path_serverside@$host_clientside$path_clientside@ @$path_serverside@$path_clientside@\""
set stream_expression_cmd "STREAM::expression \"@$host_serverside$path_serverside@$host_clientside$path_clientside@\""
set stream_enable_cmd "STREAM::enable"
log local0. "$log_prefix: \$stream_expression_cmd: $stream_expression_cmd, \$stream_enable_cmd: $stream_enable_cmd"
Execute the STREAM::expression command. Use catch to handle any errors. Save the result to $result
if { [catch {eval $stream_expression_cmd} result] } {
There was an error trying to set the stream expression.
log local0. "$log_prefix: Error setting stream expression ($result). If you enable static::RewriteResponsePayload, then you should add a stream profile to the VIP. Else, set static::RewriteResponsePayload to 0 in this iRule."
No error setting the stream expression, so try to enable the stream filter
Execute the STREAM::enable command. Use catch to handle any errors. Save the result to $result
if { [catch {eval $stream_enable_cmd} result] } {
There was an error trying to enable the stream filter.
log local0. "$log_prefix: error enabling stream filter ($result)"
log local0. "$log_prefix: Successfully configured and enabled stream filter"
Fix Location, Content-Location, and URI headers
foreach header {"Location" "Content-Location" "URI"} {
set protocol [URI::protocol [HTTP::header $header]]
log local0. "$log_prefix: Checking $header=[HTTP::header $header], \$protocol=$protocol"
if {$protocol ne ""} {
set server_path [findstr [HTTP::header $header] $host_serverside [string length $host_serverside]]
if {$server_path starts_with $path_serverside} {
if { $static::ProxyPassDebug } {
log local0. "$log_prefix: Changing response header $header: [HTTP::header $header] with $protocol://$host_clientside$path_clientside[substr $server_path [string length $path_serverside]]"
HTTP::header replace $header $protocol://$host_clientside$path_clientside[substr $server_path [string length $path_serverside]]
Rewrite any domains/paths in Set-Cookie headers
if {[HTTP::header exists "Set-Cookie"]}{
array unset cookielist
foreach cookievalue [HTTP::header values "Set-Cookie"] {
set cookiename [getfield $cookievalue "=" 1]
set namevalue ""
set newcookievalue ""
log local0. "CookieName = $cookiename ProxyPass"
log local0. "CookieValue = $cookievalue ProxyPass"
foreach element [split $cookievalue ";"] {
set element [string trim $element]
log local0. "Element = $element ProxyPass 1"
if {$namevalue equals ""} {
set namevalue $element
if {$element contains "="} {
set elementname [getfield $element "=" 1]
set elementvalue [getfield $element "=" 2]
if {[string tolower $elementname] eq "domain"} {
set elementvalue [string trimright $elementvalue "."]
if {$host_serverside ends_with $elementvalue} {
if {$static::ProxyPassDebug > 1} {
log local0. "$log_prefix: Modifying cookie $cookiename domain from $elementvalue to $host_clientside ProxyPass"
set elementvalue $host_clientside
append elementvalue "."
if {[string tolower $elementname] eq "path"} {
if {$elementvalue starts_with $path_serverside} {
log local0. "$log_prefix: Modifying cookie $cookiename path from $elementvalue to $path_clientside[substr $elementvalue [string length $path_serverside]] ProxyPass"
set elementvalue $path_clientside[substr $elementvalue [string length $path_serverside]]
append newcookievalue "; $elementname=$elementvalue"
append newcookievalue "; $element"
set cookielist($cookiename) "$namevalue$newcookievalue"
HTTP::header remove "Set-Cookie"
foreach cookiename [array names cookielist] {
log local0. "Remove CookieName = $cookielist($cookiename) ProxyPass"
HTTP:header insert "Set-Cookie" $cooklist($cookiename)
log local0. "$log_prefix: Inserting cookie: $cookielist($cookiename)"
Cookies are unable to be generated when having HttpOnly.
this is mine.
irule
ltm rule qux {
if { [HTTP::header exists "Set-Cookie"] } {
set namevalue ""
if { $namevalue equals "" } {
if { $element contains "=" } {
if { [string tolower $elementname] eq "domain" } {
HTTP::header insert "Set-Cookie" $cookielist($cookiename)
log local0. "Inserting cookie: $cookielist($cookiename)"
client
[root@bip8:Active:Standalone] config curl -I http://172.28.24.10
HTTP/1.1 200 OK
Date: Fri, 08 May 2015 06:42:12 GMT
Content-Length: 89
Set-Cookie: cookie1=value1; Path=/; HttpOnly
/var/log/ltm
[root@ve11c:Active:In Sync] config tail -f /var/log/ltm
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : CookieName = cookie1 ProxyPass
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : CookieValue = cookie1=value1; Path=/; HttpOnly ProxyPass
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Element = cookie1=value1 ProxyPass 1
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Element = Path=/ ProxyPass 1
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Element = HttpOnly ProxyPass 1
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : CookieName = PHPSESSID ProxyPass
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : CookieValue = PHPSESSID=eur026tal67g54keu6oj5gphh6; expires=Fri, 08-May-2015 13:23:10 GMT; path=/; domain=www.supportourtroopscanada.com.; HttpOnly ProxyPass
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Element = PHPSESSID=eur026tal67g54keu6oj5gphh6 ProxyPass 1
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Element = expires=Fri, 08-May-2015 13:23:10 GMT ProxyPass 1
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Element = path=/ ProxyPass 1
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Element = domain=www.supportourtroopscanada.com. ProxyPass 1
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Remove CookieName = PHPSESSID=eur026tal67g54keu6oj5gphh6; expires=Fri, 08-May-2015 13:23:10 GMT; path=/; domain=www.supportourtroopscanada.com.; HttpOnly ProxyPass
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Inserting cookie: PHPSESSID=eur026tal67g54keu6oj5gphh6; expires=Fri, 08-May-2015 13:23:10 GMT; path=/; domain=www.supportourtroopscanada.com.; HttpOnly
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Remove CookieName = cookie1=value1; Path=/; HttpOnly ProxyPass
May 8 15:01:17 ve11c info tmm[15145]: Rule /Common/qux : Inserting cookie: cookie1=value1; Path=/; HttpOnly
anyway, if you want, you may use string map to remove httponly (i.e. replace it with null).
set cookievalue [string map -nocase {"httponly" ""} $cookievalue]
