how to schedule to display web page maintenance every month ?
I want to schedule to display web page maintenance every month use irule. could someone share your template for my reference ? Thanks
Whilst it’s possible, iRules are event driven so it’s not very practical to schedule them to display something at a certain time. It might be easier to automate applying a different iRule to the virtual server at the times you want to display the maintenance page
Hi PC,
You can trig your maitenance page using Irule above:
   "clock seconds" will return the time in seconds
   "clock format" will format the previous value with it's date/time components
   split will chop the returned string into a list of elements.
  set l [split [clock format [clock seconds] -format {%A %H}] " "]
   Next add the time check logic:
   This example will process the log statement on Sunday between 3 and 4am.
  if { ([lindex $l 0] eq "Sunday") &&
       ([lindex $l 1] >= 3) &&
       ([lindex $l 1] < 4)  } {
     Put in iRule logic here
    log local0. "processing iRule..."
For info i retrieve the irule in this post:
