How to run scripts on F5
Hi The client will be giving some scripts relating to maintenance pages ..which need to be executed…can any one please let me know how to run these scripts in F5.
Thanks, Imran
It all depends on type of scripts..
Ansible- GitHub - F5Networks/f5-ansible: Imperative Ansible modules for F5 BIG-IP products · GitHub
Python- https://devcentral.f5.com/questions/f5-icontrol-python-for-beginners-54051
Powershell- GitHub - joel74/POSH-LTM-Rest: PowerShell module and scripts for working with F5's LTM REST API · GitHub
Can you clarify if you’re talking about scripts running on the BIG-IP like a cron job, or scripts that an iRule may need to parse through or scripts that run on the web pages that BIG-IP will need to run?
Its Scripts that run on web pages
