Hi Everyone,
I have BIGIP’s in 2 sites, I need to copy only the new configuration to another site and vice versa without backup/restore UCS files to avoid re-active lic, provisioning, monitor alerting etc…
case 1: i have to copy the config to DR site for specific VS Case 2: i have to copy from DR BIGIP to Production BIGIP
so I took config files from both devices “bigip.conf” and “dr_bigip.conf” and run them against text compare and hereunder the differences, so how to pasted them on DR BIGIP
ltm node /Common/Corporate_Staging_Corpay {
address x.x.x.x
ltm pool /Common/Corporate_Staging_Corpay {
members {
/Common/Corporate_Staging_Corpay:443 {
address x.x.x.x
monitor /Common/https
ltm snatpool /Common/Corporate_Staging_Corpay_SNAT {
members {
/Common/x.x.x.x
ltm profile client-ssl /Common/Corporate_Staging_Corpay_Client {
app-service none
cert /Common/ACH_Staging_Corpay.crt
cert-key-chain {
ACH_Staging_Corpay_ACH_Staging_Corpay {
chain /Common/ACH_Staging_Corpay.crt
key /Common/ACH_Staging_Corpay.key
defaults-from /Common/clientssl
inherit-certkeychain false
passphrase none
ltm profile server-ssl /Common/Corporate_Staging_Corpay_Server {
app-service none
defaults-from /Common/serverssl
ltm policy /Common/asm_auto_l7_policy__Corporate_Staging_Corpay {
controls { asm }
requires { http }
rules {
default {
actions {
1 {
asm
enable
policy /Common/Corporate_Staging_Corpay
ordinal 1
strategy /Common/first-match
ltm policy /Common/asm_auto_l7_policy__Customs-Pro-Temp {
controls { asm }
requires { http }
rules {
default {
actions {
1 {
asm
enable
policy /Common/Customs-Production-blocking
ordinal 1
ltm virtual /Common/Corporate_Staging_Corpay {
destination /Common/x.x.x.x
ip-protocol tcp
mask 255.255.255.255
policies {
/Common/asm_auto_l7_policy__Corporate_Staging_Corpay { }
profiles {
/Common/ASM_Corporate_Staging_Corpay { }
context clientside
context serverside
/Common/HTTP-Xforwad { }
/Common/tcp { }
/Common/websecurity { }
security-log-profiles {
/Common/QRadar
/Common/Request&Response
source 0.0.0.0/0
source-address-translation {
type snat
translate-address enabled
translate-port enabled
asm policy /Common/Corporate_Staging_Corpay {
active
encoding utf-8
policy-template POLICY_TEMPLATE_FUNDAMENTAL
security bot-defense asm-profile /Common/ASM_Corporate_Staging_Corpay {
app-service none
