How to rewrite HTTP links in pages dynamically
I have situation. We have Intranet portal let say and inside there are link to other intranet web sites for example
We wanted to host Intranet portal to the internet. I have published the portal with LTM and APM module successfully. However, the links e.g. will not work from the internet as we can’t solve the DNS to servername_1. Is there any way to do the HOST ADDRESS TRANSLATION (HAT) to translate dynamically the link
to something like https://www.company.com/webapp/start or similar
so that when client click the link the request goes to F5 and F5 again sent the request to the server with thehttp://serverhostname_1:8100/webapp/start.
I don’t know if HTTP_response, or HTTP profile, or ProxyPass can solve this challenge. Please advise. Thanks a lot in advance.
RSS
hello, you can use either an irule with stream profile : DevCentral - An F5 Technical Community
or you have directly in the gui a LTM rewrite profile. Test this first as it is simpler to manage.
