Hi, how can I reset to the factory default a big-ip with version 10.1 installed, including the configuration of the ASM Module? I read that the “sys-reset” command can do that, but doing a “find / -name sys-reset -print” I can’t found it… thanks!
In 10.x, you can use image2disk:
SOL10519: Resetting a BIG-IP version 10.x configuration to the factory default settings
Aaron
